本版块有VIP用户组: VIP - Delcam(点击加入),有效期内可以在版块内享受:观看视频不扣贡献、不扣大米、播放器关闭广告 等特权。
  • 视频来源:开思网
  • 视频作者:开思视频
  • 语言字幕:国语(无字幕)
  • 视频时长:21:38
  • 播放次数:29488
[现场录像视频] 【1-5-5】Delcam PowerMILL 编程效率与质量分析
liujunyun 发表于 2011-7-15 11:32:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Delcam PowerMILL 编程效率与质量分析视频总汇
【5-1】https://v.icax.net/thread-3715-1-1.html
【5-2】https://v.icax.net/thread-3717-1-1.html
【5-3】https://v.icax.net/thread-3720-1-1.html
【5-4】https://v.icax.net/thread-3721-1-1.html
【5-5】https://v.icax.net/thread-3723-1-1.html<您在这>
  Surface finish Quality
  Controlling toolpath Point spacing
The ability to "fine tune"the point-to-point data in the toolpath will ensure the machine tool is running at its best and will improve surface finish.Can benefit both 3 axis and 5 axis applications.
  Point distribution 5 axis example
  A right tool setup extend tool life and improves surface finish
a.
few interfaces as possible(minimum addition of tolerances)
b.Recommended max run-out using a solid carbide end mill: 10 μm
c.Each added 10 μm run-out will reduce tool life by 50%
d.Spindle,tool setup,its overhang and unbalance do influence the maximum usable spindle speed
  Benefits of automatically the Maximum Tool Holder Prodile for a given tool
a.
Quik and easy selection of the most rigid tool holder and overhang combination
b.No time consuming Tool Holder Collision Checks
c.Reduced vibaration
d.Faster feedrate
e.Extend tool life
f.Better quality surface finish+less hand finishing
  Tool Axis Smoothing
a.
Smooth 5 axis rotary movement is essental for obtaining a good quality surface finish
b.Any Sudden or large change in the rotary axis over a small distance will leave undesirable cutter marks on the finished part
关于徳慷
广州市德慷软件公司是英国达尔康软件公司(Delcam Plc)指定的华南地区代理商, 拥有一支高素质的技术工程和销售队伍,能及时地为广大用户提供技术支持和完善的售后服务。它的前身为DELCAM广州办事处和DELCAM华南技术中心。
关于Delcam
Delcam Plc 是世界领先的专业化CAD/CAM软件公司。其软件产品适用于具有复杂形体的产品、零件及模具设计制造,广泛地应用于航空航天、汽车、 船舶、内燃机 、家用电器、轻工产品等行业。特别对塑料模、压铸模、橡胶模、锻模、大型覆盖件冲压模、玻璃模具等的设计与制造具有明显的优势。
更多关于Delcam请点击:
https://www.delcam.com.cn
更多关于本次研讨产品发布会请关注近期更新视频。
Cieya 发表于 2011-7-15 11:32:41 | 只看该作者
zhzociboss 发表于 2011-7-16 17:04:02 | 只看该作者
wkxq 发表于 2011-7-24 22:49:41 | 只看该作者
eng1875 发表于 2011-9-14 15:30:20 | 只看该作者
GMT+8, 2026-7-27 08:34 , Processed in 0.058705 second(s), 17 queries , Gzip On, Redis On.
